best wet grip?
- troggy
- gusthegorilla
- troggy
I'll get down the beach tomorrow!
- Thank you received: 2004
A jimny is not and never will be a touring car, it cannot corner at high speed in anything like a controlled manner it is simply not designed like that. Driven at an appropriate speed for the prevailing conditions a jimny is perfectly stable and able to make some decent progress but it is generally slower than most modern hatchback cars available. Drive it with a view to being able to stop in the distance you can see the road in front of you and you will be golden. Try to make it handle like something it is not and then drive the wheels off it and it will punish you.
11/60 wrote: I'm sorry but adding weight to the back of a jimny to improve the rear grip is like putting a sticking plaster on a severed arm, not particularly helpful. If you add more weight yes sure in the first instance it will have some more grip but when the limits of this new grip are found then it will take even less time to let go and even more skill to rectify. It is not the answer especially, as suggested, for an newish / younger driver.
+ 1
Check the manufactured date code on the tyre sidewall. If older than 5 year old even if it has plenty of tread, replacing them with will make a big difference. However, with a Jimny, any failing component on the suspension or steering can also magnify poor grip issues.
