Powertrax lock right
21 Nov 2015 13:42 - 21 Nov 2015 13:44 #156779 by Mike G
Powertrax lock right was created by Mike G
Hi,
I'm installing a powertrax in my rear diff, I've checked the backlash and marked all the parts to correctly orientate the carrier, bearing adjusters and ring gear when replacing it. But going through the instructions for installation in lockrights manual, it says to re-use the thrust washers for the side gears.
I bought the locker from jimnybits store and read on the page that one of the two thrust washers for each side gear 'must be removed'. I don't like straying from the instructions as I know diffs can be a nightmare to set up and get working correctly, but I'm guessing the guys at jimnybits are talking from experience and it's possible that this version of the lockright is used in other diffs as the instructions don't specify that it's for a jimny installation.
I've tried fitting the lockright with the both thrust washers on one side, but it doesn't seem to want to fit, however, if I do remove one of the thrust washers, it will probably fit with a bit of belt sanding to the crossmember centre union (that's what I'm calling it anyway).
Just wondered if anyone else has came across a similar predicament?
powertrax installation manual
click here
jimnybits powertrax entry
click here
2" Trailmaster suspension lift, 2"body lift, snorkel, full breather kit, 29" steel wheels with BFG tyres, tinted rear windows, CRT CB radio with modulator antenna mounted on rear, dog cage and tray in the back.
Last edit: 21 Nov 2015 13:44 by Mike G.
  • RichiesJimny
21 Nov 2015 16:27 - 21 Nov 2015 16:28 #156791 by RichiesJimny
Replied by RichiesJimny on topic Powertrax lock right
There's two thrust washers on either end, remove the thicker washers and rebuild it with the two thiner washers and use standard gearbox oil and you'll find that it unlocks easier when conrnering
Last edit: 21 Nov 2015 16:28 by RichiesJimny. Reason: Spelling
21 Nov 2015 16:30 #156792 by Mike G
Replied by Mike G on topic Powertrax lock right
Thanks Richie,
I wondered what the reason was for taking the washers out due to it not being in the installation manual. That makes things a lot clearer.
  • TomDK
21 Nov 2015 16:52 #156796 by TomDK
Replied by TomDK on topic Powertrax lock right
flashg0rd0n wrote: Thanks Richie,
The manual is for a samurai. Probably the reason why it's not 100% accurate.
21 Nov 2015 16:59 - 21 Nov 2015 17:09 #156797 by Mike G
Thanks Tom,
That ties up with a video I watched on youtube. Guy there was doing a samurai diff, looked exactly the same design, but he explicitly underlined that the thrust washers were to be left in place. Guess it's because powertrax are an American company and Suzuki don't have a market for new cars there anymore. The diffs do look exactly the same though, but it was a different lockright model number that was used.
Last edit: 21 Nov 2015 17:09 by Mike G. Reason: additional information
