'How to' guide mistake?
  • troggy
17 Nov 2015 16:05 #156488 by troggy
'How to' guide mistake? was created by troggy
Checking prob on vacuum, I found the 'how to' on it.
Point 7 says the lock tube is 'the top one, marked 2'
Point 13 says the unlock tube is the upper one, marked 2'
Am I missing something,??
  • troggy
17 Nov 2015 16:13 #156489 by troggy
Replied by troggy on topic 'How to' guide mistake?
The plan is, when the weather permits, is to make my own copper tube system, routed in the engine bay against the bulkhead, then down to the hubs, with the shortest run of piping I can design, copper as far as, the rubber/silicone for the flexi bits.
I have already moved the solenoid thingys to next to fuse box for easy access, and rerouted the interesting pipework around here (using tubing for watering hanging baskets).
If the vacuum store ws taken out, would it affect anything? I don't need to swich the hubs without the engine running, it's just another potential fail point.
Any comments?
  • troggy
17 Nov 2015 19:10 #156509 by troggy
Anyone know which is which?
  • troggy
17 Nov 2015 19:36 #156514 by troggy
This is for daughter's (greenpig) car. I intend to beat her vacuum system into submission and FORCE it to work. Then all I have to do is find out why her transfer box refuses to disengage. Anyone know what operates the on/off of a push button transfer box? Is it a little electric motor?
  • troggy
18 Nov 2015 18:29 #156590 by troggy
once I've made the prototype, it could be a great replacement for the outrageously convoluted system of pipes and tubes, so prone to leaky rubber and corroded steel tube, and access to the control gubbins saves a lot of skinned knuckles. No doubt a replacement vac tube system running over the front axle :blink: would cost a gazillion pounds from suzuki!
  • troggy
18 Nov 2015 19:25 #156597 by troggy
Went to the 'local'garage and noticed some packs of 3/16th copper tube. Asked the boss man for a price but he couldn't think so I said 'a tenner'. Yeah that's about right. Got a pack of fags from his missus (tubbs) to sweeten the deal. Avoided looking at the 'precious things' in the shop.
Hinderwell, twinned with Royston Vasey.
Making the vac system tomorrow.
Time to create page: 0.090 seconds
