worn bushes
- rexthecat
15 Nov 2015 20:16 #156345
by rexthecat
worn bushes was created by rexthecat
I think I might have a worn bush on the rear arm, haven't checked yet but sounds a bit like something rattling round in the back, theres no seats but everything thats in the back is ratcheted down. I know how to check if its the bearing but how do I check for a worn bush? just looking for play and visual inspection?
Had a look around at bush removal tools seem generally pricey, cheaper to go to a garage! but ebay seem to have a kit for about £85, anyone tried these? any good or too cheap to be true?
ta
ta
- mickt
16 Nov 2015 18:28 #156421
by mickt
Replied by mickt on topic worn bushes
The Mot chaps use levers to put them under load to check them. They picked up the rear offside lower arm as having slight wear but not enough to fail. They lever the arm against the chassis to see if there is any delam or excessive movement in each bush. I got a full set for both rears for £24.70 off the ebay delivered in 5 days from Australia, or so it said as the auction was in Aussie dollars but ebay does the conversion.
Time to create page: 0.089 seconds
