Tire pressure question?
  • 1066Boy
15 Nov 2015 18:25 #156325 by 1066Boy
Tire pressure question? was created by 1066Boy
I know i am new to the world of Jimny but not to vehicles in general. :)
I cant get my head around the recommended tire pressures for the Jimny. :unsure:
The book recommends 23psi front, 26psi rear i think. Why on such a short, front
heavy vehicle would you run lower pressure on the front?
15 Nov 2015 18:37 #156327 by facade
Replied by facade on topic Tire pressure question?
Possibly to give a larger contact patch on the front, where you want most grip?
I can't recall any vehicle I've owned in well over 30 years that had higher pressure in the front than the rear.
  • 1066Boy
15 Nov 2015 19:31 #156333 by 1066Boy
Replied by 1066Boy on topic Tire pressure question?
facade wrote: Possibly to give a larger contact patch on the front, where you want most grip?
My Alfa 159 runs at 39psi front 36psi rear, probably due to the heavy engine. :)
Unless you are running fully loaded all the time i would of thought that 23psi all round
would make more sense? With the Jimny being so short and a bit skittish in the wet,
would this not help with rear grip? :unsure:
Time to create page: 0.141 seconds
