Constant problems
- mark_w
11 years 5 days ago #156235
by mark_w
Constant problems was created by mark_w
Hi guys, long story short, my poor jimny has been in and out of the garage these past few months.
The biggest cost was over £1500 to fix. Knackered gears, transmission box and other stuff.
Recently it's starting to show some bad signs again.
When I pull away, especially up hill I hear a loud mechanical clunking noise and I can feel something beneath the car rumble.
It seems to be coming from the back end of the car as opposed to the engine. Anyone have any ideas what the problem could be?
Last time I ignored a noise for too long it cost me nearly as much as I paid for the car.
I know practically nothing about cars which doesnt help.
Thanks guys.
Thanks guys.
11 years 5 days ago #156236
by j999pre
Grey pick up Jimny
Replied by j999pre on topic Constant problems
Could be gearbox mount or transfer box mount
It could be diff or rear prop
Or radius arm bushes or panhard bushes
Post your location and maybe someone local can have a look for you?
Grey pick up Jimny
The following user(s) said Thank You: mark_w
- mark_w
11 years 5 days ago #156239
by mark_w
Replied by mark_w on topic Constant problems
Thanks for the info
I'll do some research into it. Definetly need to learn more a out cars but no idea where to start.
I'm in gateshead and every garage i've been too seems to fix one problem and cause another -.-
- mickt
11 years 5 days ago #156252
by mickt
Replied by mickt on topic Constant problems
That is what the bad ones aim to do!!!! You need to get under the car and start a methodical inspection of all the possible guilty components. Where you have two of something across the axle say i.e. wheel bearings, shock absorbers, springs , trailing arms etc try and see if there is anything at all different as far as obvious signs, leaks, broken bits, play in moving surfaces like the bearings or whatever before you take "a noise from the back" to a garage as it could save you pounds. Notice when and from where the noise comes and goes i.e. under braking or accelerating or coasting or turning left or right. Get some one to bounce on each corner of the car whilst you look underneath. Explore anything and everything to try and pin something down and by a process of elimination you might find your culprit. There are a couple of members from up your way, Page in Acklington is a very nice and helpful chap who I am sure will be glad to advise you if you ask him nicely.
11 years 5 days ago #156268
by facade
Replied by facade on topic Constant problems
Don't confine the search to the back either. I spent ages on a rumble that definitely came from the back axle.
I eventually cured it when I changed a front wheelbearing. :whistle:
I only found that because the brake pedal went down too much first press, but second press it was fine.
- mark_w
11 years 5 days ago #156273
by mark_w
Thanks for the advice guys!
I'll get underneith this Sunday and see if I can spot anything.
Time to create page: 0.101 seconds
