Transfer box not disengaging
- troggy
11 years 1 week ago #155992
by troggy
Transfer box not disengaging was created by troggy
Hello again.
Nasty noise like transmission prob increasing with speed.
Changed wheel bearing which was shot (tool from big jim shop worked a treat)
Same noise
Put her in 4wd, green light flashing but seemed to be in 4wd (up a muddy road).
Pressed 2wd, noise gone
BUT green light still flashing.
Drove around a bit, fine. Parked up, pressed and held 2wd button, light went out but noise back!
4wd again, then 2wd, noise gone light flashing.
Checked wheels- unlocked, wiggled prop shaft and is still connected to front shaft???
Seems transfer box not disengaging, any ideas? (push button type)
Ta muchly.
Same noise
Ta muchly.
- troggy
11 years 1 week ago #155994
by troggy
Replied by troggy on topic Transfer box not disengaging
Just to add a bit.
The noise sounds like one hub has locked and is winding stuff up, but that's prob not it, it just has that sound.
I don't mind the front diff turning in 2wd as the hubs are unlocked and I can't see them locking on their own.
It's daughter's (greenpig) car though and if things went ***s up when she was driving, she'd throw a wobbly! :S
- troggy
10 years 11 months ago #156820
by troggy
anybody?
Rhinoman knows, I bet.
10 years 11 months ago #156853
by Rhinoman
Replied by Rhinoman on topic Transfer box not disengaging
I had a similar problem with mine and it was a hub not disengaging. Is the light still flashing? its worth unplugging the connector from the rear of the transfer case and spraying some contact cleaner in there.
The following user(s) said Thank You: troggy
10 years 11 months ago #156866
by kirkynut
Replied by kirkynut on topic Transfer box not disengaging
Sounds like it's sticking in 4wd when you press 2wd and it's winding up.
Try reversing a short distance as you push the 2wd button.
- auchenblae
- Elite Member
- Thank you received: 25
10 years 11 months ago #156873
by auchenblae
eddie
24 Swift Ultra ALLGRIP
16 SZ3 gone 25
07 JLX+ gone 16
99 JLX gone 07
Replied by auchenblae on topic Transfer box not disengaging
Using an E10 socket take the freewheeling hubs off and check that one has not come appart.
eddie
16 SZ3 gone 25
07 JLX+ gone 16
99 JLX gone 07
Time to create page: 0.095 seconds
