4WDL quesstion
- tomlinson
My question was in regard to the manual, where it shows you selecting 4WD and the axle 'locking' with air locking hubs.
1: Which axle is locking (front or back)?
2: Why does it lock?
3: What does the locking do?
4: What are air locking hubs?
I've kind of got my head round why you shouldn't use 4WD on tarmac as the Jimny doesn't have a centre diff, right? Even though the guy said you could do it....
I just like to understand stuff that's all, so...if ur a techy who can explain to a noob I'd much appricate it. Thanks in advance of any help.
- rogerzilla
tomlinson wrote: I'll start buy saying I have little knowledge of 4WD, but I'm learning :dry: I asked a guy in the Suzuki dealership where I just bought my 15 Jimny from, but could tell he even knew less than me.
1. The Jimny is normally rear wheel drive. Selecting 4WD engages the front hub locking mechanism so both front wheels and rear wheels are driving. There is no differential between front and back, so you must NOT engage 4WD except on loose or slippery surfaces (wet tarmac is not slippery enough, but off-road, snow or gravel roads are OK). Otherwise there is a lot of torsion building up in the propshafts which will eventually damage the transmission, makes steering difficult and can be dangerous if you jack the car and it suddenly unwinds!
2. So the whole weight of the car can be used to get traction in difficult conditions.
3. Locks the front wheels to the front axle.
4. They are actually vacuum locking; when you press the 4WD or 4WD-L switch, a collar slides inside the hubs and locks a set of splines together. The collar stays there until you go back into 2WD (vacuum is not required just to maintain 4WD).
Suzuki dealers don't always understand Jimnys because they sell very few of them. Luckily the salesman who sold me mine had a very old Jimny and used it for off-roading, so he knew what he was taking about.
- tomlinson
Just ine final question :blush: ...when the locking hubs engage does the front differential lock as well? or can both wheels turn at different speeds?
Many Thanks
- rogerzilla
Incidentally, a differential always allows the wheels to rotate at different speeds. What you may be thinking of is a limited-slip differential which avoids a wheel spinning up by limiting the extent to which one can rotate faster than the other. The Jimny doesn't have these and they are more common on fast road cars. An open diff always gives equal torque on each side, which is normally fine but on a very slippy surface, a spinning wheel requires virtually no torque - so the wheel on the other side gets no torque either. The Jimny gets round this by always maintaining drive to the other axle.
- tomlinson
