Changing front foglight bulbs on a 14 plate
  • rogerzilla
  • Visitor
  • Visitor
21 Nov 2015 19:08 - 28 Nov 2015 11:08 #156825 by rogerzilla
Replied by rogerzilla on topic Changing front foglight bulbs on a 14 plate
I worked it out, as evidently no-one has a current model!
You simply lie under the car and you can reach the back of the lamp - there is quite a big gap at the inboard end of the arch liner and no dismantling is necessary. The bad news is that the lamps on the new model are now H11 and I (using an incorrect guide) bought H3. Suzuki - why on earth don't you put the fog bulbs in the owner's manual???
Last edit: 28 Nov 2015 11:08 by rogerzilla.
  • troggy
  • Visitor
  • Visitor
23 Nov 2015 19:37 #157060 by troggy
Replied by troggy on topic Changing front foglight bulbs on a 14 plate
We are all too tight to buy the newest model.......... :laugh:
Glad you got it sorted.
  • rogerzilla
  • Visitor
  • Visitor
28 Nov 2015 11:15 #157394 by rogerzilla
Here's the best way to do it, now I've got round to the job.
Under the car, remove the two bottom trim clips from the wheel arch liner. These have a cunning three-legged outer piece (why?) which prevents use of the usual V-shaped tool to remove the centre plastic pin, but fingernails will work. The whole clip comes out as soon as the centre pin is pulled out a bit.
Access is now quite good, and a torch or inspection lamp is handy. Press the retaining tab in and remove the cable. The bulb can then be undone by turning it anti-clockwise. Reassembly is the reverse of removal, except a lot easier.
Just for the record, the bulbs are H11 now. Not H3 or H8, as you will find variously specified on retailers' websites for a 2014 Jimny.
21 Dec 2015 16:04 #158918 by Tikka 260
New to the site, and getting lots of useful info already.
Question on the fog lamps - what is the best replacement bulb to increase the brightness ? There are many LED sizes, and I am interested to know what size to order, as I have already purchased the wrong ones H8 after following Autobulbs recommended replacement. I shall have to return them after Christmas, and would like to get the right ones in exchange.
Thanks for looking.
T260
  • rogerzilla
  • Visitor
  • Visitor
01 Sep 2023 17:15 #250631 by rogerzilla
Thread revival! My 2014 Jimny is long gone (needed more space in the rear seats!) but we now have a 2012 auto as a second car. Although the fog lights on a 2012 are in a different place to the later facelifted cars, they are still H11. I have just changed them for yellow ones, because I like yellow fogs.
