Changing front foglight bulbs on a 14 plate
- rogerzilla
- Visitor
11 Nov 2015 10:38 #155964
by rogerzilla
Changing front foglight bulbs on a 14 plate was created by rogerzilla
Does anyone know how to do this? The manual doesn't cover the foglights. I assume the bumper has to be eased away for access. I'm wary of following the instructions I've seen in Another Forum as they were for a much older car - Suzuki have moved the foglights around quite a bit over the years!
- troggy
- Visitor
11 Nov 2015 19:09 #156011
by troggy
Replied by troggy on topic Changing front foglight bulbs on a 14 plate
have you had a go behind the wheel arches?
- rogerzilla
- Visitor
12 Nov 2015 20:15 #156146
by rogerzilla
Replied by rogerzilla on topic Changing front foglight bulbs on a 14 plate
There is no access panel there. I'm sure the bumper has to come away. I will see if the screws and clips are in the same position as on the earlier model.
13 Nov 2015 07:10 #156162
by Halford
Replied by Halford on topic Changing front foglight bulbs on a 14 plate
Don't you simply need to pop out the plastic liner out from under the wheelarch :huh:
- NineCherries
- Visitor
15 Nov 2015 23:11 #156382
by NineCherries
Replied by NineCherries on topic Changing front foglight bulbs on a 14 plate
I was thinking the same as halfords.
- troggy
- Visitor
17 Nov 2015 19:15 #156510
by troggy
Pretty sure you just undo a few things under wheel arch, pull the plastic back and 'HEY PRESTO' you're in!
It's a lot less effort than taking half the front end off to change a bulb.
