g13bb common fault
- mark 88
11 years 1 week ago #155790
by mark 88
g13bb common fault was created by mark 88
hi all do jimny engines have a problem with there wrist pin going on the cylinder closest to the cam pulley. my jimny has had a second engine in now and has the same knock as the first. the first engine knock suddenly became so loud it was like a windy pick was under the bonnet and when i took the sump off i found chunks of piston skirt in it.
if i put a screwdriver to the base of the cam cover and to my ear i can pinpoint where its coming from and im praying that its a tappet but ive tried them several times.
any ideas would be great thanks
- mickt
11 years 1 week ago #155796
by mickt
Replied by mickt on topic g13bb common fault
Normal engineering term is "small end" as opposed to the cranks "big end". I would think you have just been unlucky in the replacement engine being as worn as your original. Would think its down to poor servicing through its life in not enough oil and filter changes and correct grade of oil used and possibly oil pump wear due same. The oil galleries internally probably mean that the No 1 piston is the last in the line and so the pressure when it gets there is too low to do the job properly. You could try a flush and new good oil and filter but I would not hold too much faith in fixing it. There are additives on the market that claim that they can do wonders but again tongue in cheek for to suggest they work.
11 years 1 week ago #155802
by j999pre
Grey pick up Jimny
Replied by j999pre on topic g13bb common fault
I have an engine If it gets to that point?
Grey pick up Jimny
- Russ-41
11 years 1 week ago - 11 years 1 week ago #155891
by Russ-41
My thoughts exactly.
I don't think it's common for G13's to blow head gaskets but it is well documented online (Lets not forget there are a lot of G13's out there, thus a lot that haven't blown!)
I wonder if potentially some gasket material or other crap/crud is finding its way in to your oil galleries (sadly on both the engines youve had which could only ever end badly. Its likely to end up at the end of the line (or crank in this case) or get stuck in a place that has a low pressure flow and can't clear it.
Replied by Russ-41 on topic g13bb common fault
mickt wrote: Normal engineering term is "small end" as opposed to the cranks "big end". I would think you have just been unlucky in the repl............... .................. do wonders but again tongue in cheek for to suggest they work.
Last edit: 11 years 1 week ago by Russ-41.
- mark 88
11 years 1 week ago #155918
by mark 88
Replied by mark 88 on topic g13bb common fault
on the good side ive got my old knackered engine to practice on lol thanks
- mickt
11 years 1 week ago #155928
by mickt
You could make a good engine by using the spare engine for parts!
Time to create page: 0.101 seconds
