how to set intake tappets
  • mark 88
11 years 1 week ago #155740 by mark 88
how to set intake tappets was created by mark 88
hi all my engine has a tap coming from the the tappets for the cylinder closest to the cam pulley. setting up the exh clearances is easy but the adjuster for the intake seems to sit in a recess in a shaft and therefore cant get the feelers in so i tried to slide the feeler between the top of the valve stem and the rocker but there is a bracket/cup thing stopping me from getting it through. the only option seems to be is to slide the feeler between the back of the cam and the curved face of the rocker which seems a bit hity missy since as the feeler bends between the cam and the rocker which gives that slight dragging feel which indicates correct gap when its not.
is there a trick that im blatantly missing ??
any help and past experience would be great thanks all
11 years 1 week ago #155753 by Rhinoman
Replied by Rhinoman on topic how to set intake tappets
For a G13BB engine the FSM states:
Note: When checking valve clearance, insert thickness gauge between camshaft and cam-riding face of rocker arm
  • mark 88
11 years 1 week ago #155788 by mark 88
Replied by mark 88 on topic how to set intake tappets
fair enough cheers
Time to create page: 0.081 seconds
