Vac hubs
- Lazia23
11 years 1 week ago #155641
by Lazia23
Vac hubs was created by Lazia23
So Jimny won't go into 4wd. pull the leaver and no light comes on, then about a minute later the 4wd light starts flashing. As the light doesn't start flashing straight away is assume its not a vac leak? i thought it could just be the hubs are jammed. Just before i start dis-assembling my jimny has anyone got any other ideas or am i on the right track?
Cheers,
Lazia
Cheers,
Lazia
11 years 1 week ago #155643
by facade
The light flashing with the manual transfer box indicates that the vacuum switch in the line to the front hubs (ON) is not registering vacuum after the timeout period. (15 seconds, a minute is rather too long, either the lamp should be fully lit, or flashing after 15 seconds from moving the lever)
The first time mine did this was because the OFF valve wasn't returning fully, and was venting the vacuum tank to atmosphere, so no vacuum could be established in the ON lines.
The second time was because the front wheelbearing was collapsed and leaking round the seal.
The following user(s) said Thank You: Lazia23
- Lazia23
11 years 1 week ago - 11 years 1 week ago #155645
by Lazia23
Replied by Lazia23 on topic Vac hubs
just timed it, 18 seconds. my time keeping's gone to shit haha. I have those weird alloys with the hubs set inside the wheel so manuals aren't a option. Here's the plan, jack the front up, wheels off, runt the system. see what moves, see what doesn't. move the system by hand and see whether it makes a difference. if not disassemble the system, lubricate the moving parts with WD40 and see what happens. if not then the soapy water's coming out to try and find a leak.
sound good?
Lazia
sound good?
Lazia
Last edit: 11 years 1 week ago by Lazia23. Reason: put my real name in
11 years 1 week ago - 11 years 1 week ago #155648
by facade
You won't find a vacuum leak with soapy water
There are a couple of "how to's" about if you search, but basically
1) check for broken/split missing pipes (the one from the engine to the vacuum valves often comes off, the one where the flexible pipes go onto the leading arm, and the ones that go to the trunions/swivel housings.
2) Whip the wheels off, disconnect the lower (I think the lower pull the hubs on) rubber pipes at the trunion and block them with a nail or something.
Try selecting 4wd, if the lamp comes on, the leak is in the wheelbearings. If not then it is most likely a sticking solenoid valve, because damp gets in through the little filters. Best to remove the assembly, squirt GT-85 into the ports and trigger the valve with a 12v battery a few dozen times.
The fault finding & repair guide is in the manual, section 3D-front suspension.
Lazia23 wrote: if not then the soapy water's coming out to try and find a leak.
Last edit: 11 years 1 week ago by facade.
11 years 1 week ago - 11 years 1 week ago #155743
by kirkynut
Can we have a photo of your wheels. I bet the centre cap knocks out so you can have manual hubs!
If not have a look at my sticky www.bigjimny.com/index.php/forum?view=topic&catid=7&id=55862 on making your hubs fixed.
Last edit: 11 years 1 week ago by kirkynut.
Time to create page: 0.092 seconds
