jimny 2002
  • kurt1234
11 years 2 weeks ago #155104 by kurt1234
jimny 2002 was created by kurt1234
hi i recently changed my jimny engine 2002 o2 i put a new jimny engine in it identical engine the only problem is the engine that come out has crank shaft sensore the one that ive put in doesnt have one or a place to put one?? is there a way around this?? if any one fancied giving me a call to explain heres my number or comment bellow any help would be gratefull.......thanks in advance kurt - See more at: www.bigjimny.com/index.php/forum?view=to...sthash.pi93IDXd.dpuf
11 years 2 weeks ago #155107 by j999pre
Replied by j999pre on topic jimny 2002
You need to fit your old sump to it, then drill a 18mm hole in the bottom of the oil pump to fit the sensor and still and tap a hole for the retaining bolt also.
You also need to swap the inner crank pulley from your old engine so the sensor reads the pick ups on it.
You also need swap the camshaft or the sensor ring on the back of it as this is also different. Measure the shaft diameter precisely to check the ring will swap otherwise you will need to swap the cam complete. If you swap the ring make sure it goes on the new cam in the same place add the old one.
All sound ominous but it's not too bad
Grey pick up Jimny
  • kurt1234
11 years 2 weeks ago #155108 by kurt1234
Replied by kurt1234 on topic jimny 2002
thanks for that do you reckon i would be better of putting old engine back in and put the top end of new engine on as it was lack of power due to cylinder beeing down?
11 years 2 weeks ago #155109 by j999pre
You could take the head off your old engine abd check to see what was wrong but that is up to you
Grey pick up Jimny
Time to create page: 0.091 seconds
