Death wobble !
  • Davey65
11 years 2 weeks ago #155076 by Davey65
Death wobble ! was created by Davey65
Hi Guys,
A little help needed please.
Steering wobble around 45 50 mph when slowing down on the slip road the same happens ,recent Mot and service nothing on mot all fine ie kingpin bearings wheel bearings, brakesall fine.
Any advise please.
Thanks.
The topic has been locked.
11 years 2 weeks ago #155092 by Lambert
Replied by Lambert on topic Death wobble !
An mot is not a valid diagnosis tool, just because they have not found any significant movement in the test does not mean that the bearings are in a functional condition. When I did mine there was no perceptible movement in the hubs but both lowers were fairly well worn out.
The following user(s) said Thank You: Davey65
  • Daniel30
11 years 2 weeks ago #155112 by Daniel30
Replied by Daniel30 on topic Death wobble !
Check your tyre pressures ;)
  • Decklandpt
11 years 2 weeks ago #155129 by Decklandpt
Replied by Decklandpt on topic Death wobble !
i sorted mine with new tires, they were very old. also changed the steering bar terminals as they had long died, but that did not cause death wobble
  • fozzie
11 years 2 weeks ago #155134 by fozzie
Replied by fozzie on topic Death wobble !
Ditto. Sorted mine with new tyres too!
I bought a steering damper soon after purchasing the jimmy. It helped, but it interfered with the self centring of the steering a bit. I took it off and got used to the wobble. I bought king pin sets and dust seals for the front axle with a view to change them over the Christmas break, but new tyres came first and the death wobble disappeared.
Previous to this I had balanced the old tyres twice to no avail.
11 years 2 weeks ago - 11 years 2 weeks ago #155162 by Bosanek
Replied by Bosanek on topic Death wobble !
fozzie,
it techically sounds like a curse that you cured the death wobble by changing tyres, despite having your old tyres balanced twice!
The only logical conclusion would be that the balancing machine, which was used to balance the old tyres, was not good, or that the guy who performed the balancing did not do a proper job.
Was the balancing of the new wheels done on the same machine by the same guy?
On what kind of balancing machine was the balancing of the old tyres and the new tyres performed?
I investigated that topic recently, and found out that there are apparently two types of balancing machines - balancing "in air" and balancing under pressure on the tread.
The first type is the classic/cheap machine type. They rotate the wheel on a spindle in the air. There is no external pressure applied to the tyre.
The second type is a more complex and more expensive type. Such a machine also has a spindle on which the wheel rotates, but it also has rollers which press onto the tread of the tyre, and simulate a load onto the wheel during balancing/spinning. Supposedly, balancing under such conditions is significantly more realistic, as the balancing properties of a wheel can differ significantly when under load, compared when it is spinning in thin air.
Does anyone know if this story is credible?
One car repair station in my town, which has such an advanced machine (machine Hunter 9700) claims such superiority, while another shop, which has standard balancing machine, says it's just mumbo jumbo. Well, truth and commercial interests never mix well.
Last edit: 11 years 2 weeks ago by Bosanek.
Time to create page: 0.098 seconds
