Interior Fuse Box Wire Removal
- Statey
31 Oct 2015 20:11 #154988
by Statey
Interior Fuse Box Wire Removal was created by Statey
Hi All,
Had a short recently on the tail light and the Fuse melted rather than break so my fuse box is a little melted in the corner
Unfortunately the Fuse Box hasn't got a push connector on the back so I've got another fuse box with half the loom!
Question is does anyone know how the wires are held into the terminal block?
I cant see anything clip like inside.
Any tips?
Sent from my Nexus 5 using Tapatalk
Any tips?
- Thank you received: 2004
31 Oct 2015 20:32 #154994
Replied by Lambert on topic Interior Fuse Box Wire Removal
I have never had one apart but it is probably either an integral plastic clip spring in the terminal seat on the box or an integral metal spring on the actual terminal itself either way it's a matter of finding something like the flat end of a cable zip tie to release the spring clip from the back. It will be a pita job but at least you will have enough practice to get good at doing the last few. Good luck. Btw there's probably a custom tool to do it in seconds but you can bet it is proprietary to suzuki dealers and will cost a fortune.
Time to create page: 0.073 seconds
