Kingpin bearings
  • 2013gary
27 Oct 2015 13:17 #154562 by 2013gary
Kingpin bearings was created by 2013gary
Hi all,
I attempted to change the offside king pin bearings at the weekend, but got stuck when I couldn't release the 4 hub bolts. After reading loads on this forum I understand that I don't necessarily have to remove these 4 bolts, as I can remove the bolts on the hub seal (where the grease is leaking from).
Can someone who has done it this way before please give me step by step instructions? From what I have read I remove the big hub seal, then remove the kingpins themselves by removing the 8 kingpin bolts (4 at the top and 4 at the bottom), and the whole assembly will come off. Is this correct?
Thanks for your help
  • X8GGY
27 Oct 2015 13:28 #154563 by X8GGY
Replied by X8GGY on topic Kingpin bearings
From this very board's information section -
www.bigjimny.com/images/documents/Changi...KingPin_Bearings.pdf
I followed that to do mine... B)
27 Oct 2015 13:30 #154564 by maverick
Replied by maverick on topic Kingpin bearings
I think YOU HAVE to remove the four hub bolts ... as how the heck are you going to remove the King Pins and Reams?
Jalapeño, IISY?
27 Oct 2015 13:40 #154566 by j999pre
Replied by j999pre on topic Kingpin bearings
Caliper off
8x 10mm hub seal bolts off
Track rods off the hub
2 lots of 4 12mm bolts off and kingpins off
Abs sensor off if fitted?
Pull the whole hub and cv assembly out.
You can now change the king pin bearings
If needed first you can take the vacuum hub off and the circlip behind to split the cv from the hub
Grey pick up Jimny
  • 2013gary
27 Oct 2015 14:22 #154576 by 2013gary
Replied by 2013gary on topic Kingpin bearings
j999pre wrote: Caliper off
Thanks for the help this is exactly what I was looking for. Also found this video which looks helpful:
  • X8GGY
27 Oct 2015 14:54 - 27 Oct 2015 14:55 #154578 by X8GGY
Had to watch it with mute on! ;)
Interesting... seemed to be missing mud, grease, oil, rust and stuck rod-ends and bolts though?! LOL
Dave :whistle:
Last edit: 27 Oct 2015 14:55 by X8GGY.
Time to create page: 0.094 seconds
