Overheating problem.
  • slew53
29 Oct 2015 18:28 #154827 by slew53
Replied by slew53 on topic Overheating problem.
Did you put a new radiator cap on?
29 Oct 2015 18:39 #154831 by facade
Replied by facade on topic Overheating problem.
How do you know it is overheating?
Does it blow all the water out of the expansion tank? (check radiator cap as above)
Does the temperature gauge go into the red? (could be the gauge or sensor)
  • Lewg123
29 Oct 2015 18:48 #154832 by Lewg123
Replied by Lewg123 on topic Overheating problem.
Yes changed radiator cap. And yes gauge goes up to the red. Top pipe swells right up and have to take radiator cap off to release the pressure
  • Lewg123
29 Oct 2015 18:51 #154834 by Lewg123
He's had 1.1 cap and a 0.9 cap on
29 Oct 2015 23:45 - 29 Oct 2015 23:46 #154863 by facade
Lewg123 wrote: Yes changed radiator cap. And yes gauge goes up to the red. Top pipe swells right up and have to take radiator cap off to release the pressure
The pipe is supposed to be under pressure.
In "normal" use, the water expands and the radiator pressurises to what is on the cap (0.9 bar?) this raises the boiling point of the coolant. As the water expands more, it would overpressure, so the cap lifts up and allows the expanded water into the plastic tank.
As the system cools, the water contracts, and the hoses would go flat. Atmospheric pressure on the water in the plastic tank now pushes water back into the radiator via the one way valve in the centre of the cap.
If the head gasket is badly gone, air gets into the water jacket, and not all the water gets back, when you undo the rad cap it hisses, and there is an airspace in the top.
Last edit: 29 Oct 2015 23:46 by facade.
  • Lewg123
30 Oct 2015 08:18 #154874 by Lewg123
Ok thanks. When he takes off the cap once over heated it literally blows the cap off in the air and the water just gushes out of the rad. Must be the head gasket. Thanks for the help guys
Time to create page: 0.106 seconds
