Removing the pedal block
  • Gerula
24 Oct 2015 18:59 #154344 by Gerula
Removing the pedal block was created by Gerula
Hello everyone,
During the last weeks my Jimny started to have more and more shifting problems, up to the point when it became impossible to shift gears without stopping the motor. I adjusted once the clutch cable but this only fixed the problem for a few days.
Upon careful inspection I discovered that the metal plate that holds the clutch cable's "shirt" to the pedal block is broken (pretty much the same problem described here www.bigjimny.com/forum/7-jimny-technical...ith-pedal-block.html )
It looks like the fix is to remove the pedal block and to either replace it or have it professionally welded. I would rather save money and remove the pedal block myself, is this a straightforward operation or there are any "traps" (so to speak) that I should be aware of? Any help will be greatly apreciated :)
  • Gerula
26 Oct 2015 15:31 #154465 by Gerula
Replied by Gerula on topic Removing the pedal block
No one has some experience about this operation? From what I dug up using google it would require removal of the steering column but someone managed to do it by just "lowering" the column.
  • Gerula
30 Oct 2015 12:29 #154885 by Gerula
From what I gathered it seems to be a rather common problem. No one has any input about the removal of the pedal block?
  • fozzie
30 Oct 2015 12:44 #154886 by fozzie
Replied by fozzie on topic Removing the pedal block
Sorry mate, it's not that everyone is ignoring you. It's more that we are all as much in the dark as you, and waiting for someone to enlighten us.
Like you say, if it's a common problem, somebody has done it before.
Good luck with your search and repair.
Paul
  • Jedm
30 Oct 2015 13:29 #154890 by Jedm
Replied by Jedm on topic Removing the pedal block
If you want some general advice look at a lupo forum very common issue on them there might be some help there. :)
  • Decklandpt
31 Oct 2015 20:01 #154984 by Decklandpt
Replied by Decklandpt on topic Removing the pedal block
i remember a guy at the portuguese forum that had a similar problem, but it wasnt so much the cable attachment point that failed, it was the pedal box mounts that came off.
in any case, looking at the parts on the tread you posted, and given that the jimny is not drive by wire, i would guess it's just a matter disconecting the cables and taking it of..
Time to create page: 0.106 seconds
