Breather lines
23 Oct 2015 22:34 #154295 by Mike G
Breather lines was created by Mike G
Hi all,
I'm considering fitting breathers to the axles.
Does anyone know what size the breather push-fit airline fittings should be?
2" Trailmaster suspension lift, 2"body lift, snorkel, full breather kit, 29" steel wheels with BFG tyres, tinted rear windows, CRT CB radio with modulator antenna mounted on rear, dog cage and tray in the back.
  • Muddyzook94
24 Oct 2015 08:58 #154308 by Muddyzook94
Replied by Muddyzook94 on topic Breather lines
I jus bought everything off eBay to make the breathers, I jus got 2 elbow connectors with the threaded bit going into the standard axle breathers (remember youd have to tap threads on the axle breathers) 1/8 and for the tube to go into 8mm.
24 Oct 2015 09:54 #154309 by Mike G
Replied by Mike G on topic Breather lines
Nice one,
I don't think I will fit breathers to the transfer and gear boxes yet tho, as it seems like a bit too much work. I'll wait until I need to change the clutch out.
  • Muddyzook94
25 Oct 2015 17:34 #154399 by Muddyzook94
I think it's jus the transfer box breather that is a pain to get to, all the rest is pretty straight forward tbh. Can pm you all the stuff I got for the breathers for everything if you want ?
25 Oct 2015 23:38 #154428 by Mike G
Nice one,
Thanks. I have found some 1/8" push fit airline elbows and tee connectors (all 8mm hose fitting). I've also got some 8mm tubing on order.
I've seen most breather inlets installed in the engine bay area, but I'm thinking the best place to vent everything would be to lines running up to a snorkel intake. Where did you terminate your breather lines?
  • X8GGY
26 Oct 2015 06:02 #154432 by X8GGY
Replied by X8GGY on topic Breather lines
I've used two small P-clips on the Safari mounting bolts -
To run a 10mm tube up into the snorkel head -
This comes from a manifold block in the engine bay -
Where the 10mm one to the snorkel is on the left of the block, the other 10mm on the right goes back to the Rockwatt Rocklobster box, and the three 8mm tubes going down go to the two axles and the gearbox breather -
Hope that helps...
(Mine's a slightly modified BigJimny breather kit)
Time to create page: 0.134 seconds
