Jimny brake lines
11 years 3 weeks ago #154261
by Mike G
2" Trailmaster suspension lift, 2"body lift, snorkel, full breather kit, 29" steel wheels with BFG tyres, tinted rear windows, CRT CB radio with modulator antenna mounted on rear, dog cage and tray in the back.
Jimny brake lines was created by Mike G
Hi Folks,
I'm taking both my axles off so I can modify the rear diff with the powertrax modification and give them a nice coat of paint. But looking at the brake lines, they might as well be replaced whilst I have everything off. Can anyone tell me what the outside diameter is for the brake lines and if they are copper? Sorry for the dumb question, but the lines are manky and I can't really tell.
11 years 3 weeks ago #154263
by facade
Replied by facade on topic Jimny brake lines
They are standard 3/16" brake pipe. You can use soft copper, but make sure it is secured so that there are no sections that can vibrate, as it work hardens and fractures.
The copper alloy is a lot harder to bend.
You need to reuse the old male threaded fittings, or buy new ones threaded right to the end, the common type have a plain part at the end, and only engage 2 turns in the suzuki cylinders.
11 years 3 weeks ago #154266
by Mike G
Replied by Mike G on topic Jimny brake lines
Thanks, Facade
I found THIS . I'm guessing the fittings there are the ones you warned about, they look like they have the plain part at the end.
Much appreciated.
Much appreciated.
11 years 3 weeks ago #154270
by Mike G
Actually, come to think of it. When I eventually get round to starting the front axle, I'm going to have to replace the vacuum lines for the 4x4 front hub engage/disengage system. Will these be the same material and diameter as well as fittings that were used on the brake lines? I cut the old vacuum lines off and replaced them with silicone tubing to get my by for a while. They work great, but I don't see them as a long term solution, definitely not a solution for offroad either.
I was considering using 6mm stainless steel tubing for the vacuum lines with a swagelok 3 way union on both engage and disengaging lines to split the lines to either hub.
Time to create page: 0.091 seconds
