sagging 2" lift spring question ?
  • gaz3359
11 years 3 weeks ago #154256 by gaz3359
sagging 2" lift spring question ? was created by gaz3359
Hi,I have a question regarding sagging lift springs.i have the jimnybits 2" lift springs fitted to my jimny these have been in about a year (2nd set).these past couple of weeks im noticing more and more that the passenger side front spring feels sagged.
Its mostly just me 95% of the time in the jimny, when there is no one in as expected the drivers side is slightly higher than the passenger side.when im in the jimny it seems to level out but when setting off mainly the nsf lifts quite a bit then drops when off the throttle.it also seems to lean a fair bit when going round a roundabout which is what im noticing more and more to the point it feels like im falling out the the seat, take a left hand corner all is fine.
I had a pal in the other day burly lad like myself and sat looking at the bonnet it was down on the passenger side.
I do have a winch and the battery is relocated to the ns but was never an issue 6 months ago.
anyone ever had this before ? Any suggestions ?
I still have an old lean spacer in the garage somewhere off when I first got the jimny was tempted to have a play about at the front maybe take the springs out see what the difference is like.maybe put the drivers longer spring in the passenger side and the passenger one withspacer in drivers side depending on what they look like. :huh:
  • ryanp3906
11 years 5 days ago #156219 by ryanp3906
Replied by ryanp3906 on topic sagging 2" lift spring question ?
I'd swap the front springs over myself see what that does
Time to create page: 0.069 seconds
