8 Ball CV Joint
- auchenblae
- Elite Member
- Thank you received: 25
20 Oct 2015 16:59 - 20 Oct 2015 17:00 #154018
by auchenblae
eddie
24 Swift Ultra ALLGRIP
16 SZ3 gone 25
07 JLX+ gone 16
99 JLX gone 07
8 Ball CV Joint was created by auchenblae
Sorry guys I read the thread which is about a year old but I left confused or not wanting to believe it!
My 2007 Jimny has an 8 ball CV.
The Meyle 33-144980015 I bought two off, just in case, has 6 balls and a different number of splines at the drive shaft internal end where it meets the halfshaft from the diff.
Can someone please confim that the 8 ball CV is a Suzuku dealer part only.
eddie
eddie
eddie
16 SZ3 gone 25
07 JLX+ gone 16
99 JLX gone 07
Last edit: 20 Oct 2015 17:00 by auchenblae.
- auchenblae
- Elite Member
20 Oct 2015 18:36 #154036
by auchenblae
eddie
16 SZ3 gone 25
07 JLX+ gone 16
99 JLX gone 07
Replied by auchenblae on topic 8 Ball CV Joint
Looking better this part is available and reported being in stock
Jakoparts J2828040
OEM number SUZUKI : 44102-84A00-000 - 44102-84A00
External 26 splines
Internal 29 splines
All the others are
External 26 splines
Internal 19 splines
Jakoparts J2828040
External 26 splines
Internal 29 splines
All the others are
External 26 splines
Internal 19 splines
eddie
16 SZ3 gone 25
07 JLX+ gone 16
99 JLX gone 07
- auchenblae
- Elite Member
31 Oct 2015 11:09 #154931
by auchenblae
eddie
16 SZ3 gone 25
07 JLX+ gone 16
99 JLX gone 07
The part arrived, it has 6 balls nit 8 but 29 internal splines and fitted the driveshaft on our 2007 car.
eddie
16 SZ3 gone 25
07 JLX+ gone 16
99 JLX gone 07
13 Nov 2015 15:46 - 13 Nov 2015 15:47 #156188
by Bosanek
Replied by Bosanek on topic 8 Ball CV Joint
I appear to be in the same situation as you. My Jimny was made in 2006 and will probably need a new CV joint.
I believe that the original Suzuki P.N. for an entire CV joint + halfshaft combo is 44102-84A00. However, Suzuki's part catalogue differentiates between "LH" and "RH" side. I am quite confused why!
The "RH" side is part number 44101-84A00, while "LH" side is part number 44102-84A00.
I don't know the difference betwheen LH and RH editions.
Suzuki does not sell a CV joint separately. You have to buy it already merged with a new halfshaft. The entire thing weights ~15 kg.
Anyway, you are saying that Meyle 33-144980015 CV did not fit your Jimny because it had 19 internal splines, and the original had 29 splines?
But on the other hand, the Herth+Buss Jakoparts J2828040 CV had the correct number of splines? But it had 6 balls instead of 8, and it was still compatible?
I suppose that it will be less robust and shorter lasting because of lower number or balls, shouldn't it?
How hard was it to separate the old CV joint from the halfshaft and then to install a new CV joint into the old halfshaft?
Last edit: 13 Nov 2015 15:47 by Bosanek.
- wombat
13 Nov 2015 16:23 #156190
by wombat
Replied by wombat on topic 8 Ball CV Joint
The part numbers are different because the parts are different. As they only come complete with the driveshafts they will obviously be different lengths, think about it !!
- auchenblae
- Elite Member
14 Nov 2015 10:51 #156230
by auchenblae
The CV joints are the same both sides the drive shafts are different lengths,
Are you saying Suzuki only sell both together,
eddie
16 SZ3 gone 25
07 JLX+ gone 16
99 JLX gone 07
wombat wrote: The part numbers are different because the parts are different. As they only come complete with the driveshafts they will obviously be different lengths, think about it !!
eddie
16 SZ3 gone 25
07 JLX+ gone 16
99 JLX gone 07
Time to create page: 0.092 seconds
