CV Joint Install Problem
- auchenblae
- Elite Member
- Thank you received: 25
11 years 4 weeks ago #153952
by auchenblae
eddie
24 Swift Ultra ALLGRIP
16 SZ3 gone 25
07 JLX+ gone 16
99 JLX gone 07
CV Joint Install Problem was created by auchenblae
Just in case people do not see it in chat.
Trying to change the drivers side CV Joint.
Using Martin's write up at 3 years old, 30k miles I did the nearside kingpin bearings with no problem so basically the same job.
Ok this eveing I have at least two problems but now 60k mile, 8.5 years old, so lots of North East Scotland salt on road and I think worse steel than our 99 car.
The four bolts that hold the disc back plate and hub will not move they appear to be 13mm AF but I wonder if they are 14mm AF but have rusted undersize. They are not in great condition and I can get an open ender on to them but not a ring spanner as it will not go right down on the hex maybe only half way down.
The cars has an ABS backing ring in front of the bolts so you cannot see the bolt like Martin's write up shows as that was a non ABS car.
I guess you may have to get heat in there but my little gas gun is not up to it.
Has anyone had that problem , I thought a six sided ring rather than the normal ring that only catches the bolt corners may help but as I say the bolts are not in great condition.
One of the 10mm AF oil seal ring backing plate bolts on the back of the hub has rusted undersize. I suppose a hammered on 9mm socket or get a mate to weld on a big nut.
Finally the disc back plate has seen better days so how do you get the ABS sensor out without damaging it.
Thinking the local garage may have a job as the sensible man knows when to give up.
Opinions guys - See more at: www.bigjimny.com/index.php/forum?view=to...sthash.6CXZoFUL.dpuf
eddie
16 SZ3 gone 25
07 JLX+ gone 16
99 JLX gone 07
- TomDK
11 years 4 weeks ago #153957
by TomDK
Replied by TomDK on topic CV Joint Install Problem
Why double post ?
Off with the locking hubs.
remove circlip remove the rubber gasket thing and metal rings on the inside of the knucke.
Remove both kingpin bolts.
Then you have access to the CV Joint.
You may need to unbolt the trackrod joint.
- auchenblae
- Elite Member
11 years 4 weeks ago #153959
by auchenblae
eddie
16 SZ3 gone 25
07 JLX+ gone 16
99 JLX gone 07
Replied by auchenblae on topic CV Joint Install Problem
Because I never read the Jimny Chat forum. I only read the technical forum.
I will be doing what you mentioned in the morning.
eddie
16 SZ3 gone 25
07 JLX+ gone 16
99 JLX gone 07
- mickt
11 years 4 weeks ago #154027
by mickt
Replied by mickt on topic CV Joint Install Problem
See my reply on the chat forum.
Time to create page: 0.085 seconds
