rear wheel bearings
  • m5gsx
07 Oct 2015 15:35 #153152 by m5gsx
rear wheel bearings was created by m5gsx
I have decommissioned the ABS on my Jimny, now a few months later I need to install a new rear wheel bearing, is it possible to replace with a none ABS bearing kit and save money - ie will it fit OK or is there something else forcing me to use the ABS kit ??
  • wombat
07 Oct 2015 16:39 #153163 by wombat
Replied by wombat on topic rear wheel bearings
I once by mistake fitted an abs bearing kit to a non abs axle and it started leaking after 2000 miles, but was ok after the correct bearing kit was fitted. I believe the bearings are the same but the collar that holds the bearing on and the oil seal rides on is different :) :)
11 Oct 2015 22:04 #153437 by safari
Replied by safari on topic rear wheel bearings
bearings same but collar is totally different
if u worry u die if u dont worry u still die so why worry
  • Steveolkinevel
11 Oct 2015 22:27 #153441 by Steveolkinevel
Replied by Steveolkinevel on topic rear wheel bearings
As said above the abs collar is different so I took the old one to a friend who is handy on a lathe and got him to make me one, £10 so now I buy non abs bearings and the retaining colers from him a lot cheaper.
