Fan belts.
  • StealthJimny
11 years 1 month ago #153036 by StealthJimny
Fan belts. was created by StealthJimny
Are fan belts problematic on jimny's mine squeaked one day and broke the next I got both belts replaced a few weeks ago but the alternator+fan belt is squeaking again. It's getting adjusted tomorrow but is there somthing I don't know about?
  • mickt
11 years 1 month ago #153046 by mickt
Replied by mickt on topic Fan belts.
See my forum history regarding this saga. I have just replaced the lower pulley as they can be the culprit. This is on the dual cam m13a engine. The g13bb has a solid pulley. What engine have you got in your car?
  • StealthJimny
11 years 1 month ago #153056 by StealthJimny
Replied by StealthJimny on topic Fan belts.
M13a I think...1328cc 16v
  • StealthJimny
11 years 1 month ago #153057 by StealthJimny
That's more than I was hoping lol
  • mickt
11 years 1 month ago #153089 by mickt
If it is making noises then more than likely the belt is starting to delaminate. With the heat then generated by the slippage most of the rubber from the belt will be deposited on the pulleys grooves. This is what happened to the daughters car, it started to make the noise and although the charging light did not come on the battery did go flat enough to not start the car. Luckily she had just arrived at my house for me to replace the pulley and belt. After jump starting the car I checked the voltage of the battery with the engine running and it was below 12 volts but the charge light was still off. The alt belt was still in one piece but most of the drive grooves had melted. So although the alt pulley was rotating it was not going fast enough to do any work! After replacing the lower pulley and cleaning the water pump and alt pulleys of debris rechecking the charge rate of the alt proved it was working ok. If you tighten the belt it is more likely just to snap. I would remove it and inspect it to ensure that it is still complete.
  • StealthJimny
11 years 1 month ago #153112 by StealthJimny
Cheers for you wisdom Mick, it appears it was just cruddy pulleys
I'm happy it's done just gutted I had to get the garage to sort it as it was an expense I didn't need, just need more free time in life!
Time to create page: 0.123 seconds
