Front hubs
11 years 1 month ago #152971
by BGBrit
Front hubs was created by BGBrit
Hello all,
I'm been away the last six months due to illness, though fighting on still... Took the Jimny for a ride two weeks ago green laning on some rough patches and up and down some steep hills which required 4 wheel drive at times... Only I drove on to tarmac with the 4 wheel drive engaged for about half a mile, when I noticed it I turned it off. There was, what looked like wet oil on the wheel spokes front driver side. Today I had chance to give a good look and the joint is wet and is loosing oil. My question is, can I refill this lost oil or has a seal broken etc ? any feed back welcomed...
Its a 2010 Jimny Y Reg.
BGBrit (Tony)
BGBrit (Tony)
11 years 1 month ago #152973
by j999pre
Grey pick up Jimny
Replied by j999pre on topic Front hubs
Probably kingpin bearing wear has caused the small inner cv shaft seal to fail
Jack it up and check for play at 6 and 12 o'clock
Grey pick up Jimny
The following user(s) said Thank You: BGBrit
11 years 1 month ago #152974
by BGBrit
Replied by BGBrit on topic Front hubs
Will do that very soon after I've eaten my curry...
Cheers for that..
Cheers for that..
11 years 1 month ago #152976
by BGBrit
I've been out and jacked it up,, there's some free play small maybe a millimetre or so, out of interest I checked the other side and there no free play at all and the hub is dry.
Sounds like I have one broken seal, do you think so. Is it a big job to replace the seal or has the pin worn so much it needs replacing too, and is that an easy enough job to do?
Cheers Tony.
The Jimny has 35,000 on the clock.
Cheers Tony.
- minibbb
11 years 1 month ago #152977
by minibbb
Replied by minibbb on topic Re:Front hubs
Most Jimnys need their kingpin bearings/ hub seals doing every now and then. Martin (bigjimny shop) sells the kingpin kit as a v reasonable price. There is a guide on the site on how to fit them.
I did both sides of mine last May as I had an oil seal apparent. Sadly it looks like its gone again but it lasted 18 months with a fair bit of off roading!
11 years 1 month ago #152984
Replied by Daniel30 on topic Front hubs
Time to create page: 0.086 seconds
