jimnybits 5.14:1 gears??
  • ddaann88
30 Sep 2015 23:04 #152812 by ddaann88
jimnybits 5.14:1 gears?? was created by ddaann88
has anyone here installed the jimnybits 5.14:1 gears, looked online but haven't come across anyone who uses these, and just wondering how good these are compared to other gears out there?
  • TomDK
01 Oct 2015 06:06 #152814 by TomDK
Replied by TomDK on topic jimnybits 5.14:1 gears??
There are only a few companies that makes these ratios. And I think only Calmini makes the 5.14:1, which works flawlessly :-)
You are aware the it's for an SJ / samurai transferbox right?
  • Rockwatt
01 Oct 2015 10:40 - 01 Oct 2015 10:43 #152820 by Rockwatt
Replied by Rockwatt on topic jimnybits 5.14:1 gears??
There are I believe only 3 origins for gears for the samurai box and that's trial gear billet cut and only available in 6.5:1
Then there are the calmini and various other outlets for the Chinese made gears and they are available in 4.16 5.1:1 and 6.1:1 and I'm thinking the gears that are marked up "made in Italy" and just engraved on (not stamped during production) also originate from china due to the ratios they come in.
Then there are the proper kiddies from Japan that are fully forged and ground and the best quality ive seen and made in the oem plant for Suzuki,Toyota,Mitsubishi etc. And these are available in 4.16 4.9 6.1 and 6.3, the 6.1 is lower in high than the 6.3 to accommodate bigger wheels on the road. These are sold through few outlets mainly under the rockhopper brand in aus and of course rockwatt eng in the uk.
As for RS then good luck getting some and not as good as they used to be, and all cut and welded not new!
Prices are all comparable after import etc
And this is completely unbiased as its better for me to remanufacture gears ! Just saying I know what I would buy for £40 more
Last edit: 01 Oct 2015 10:43 by Rockwatt.
  • ddaann88
01 Oct 2015 16:49 #152828 by ddaann88
Replied by ddaann88 on topic jimnybits 5.14:1 gears??
brilliant thanks for your help!
Time to create page: 0.075 seconds
