rear propshaft uj question sj prop
- gaz3359
25 Sep 2015 10:11 #152524
by gaz3359
rear propshaft uj question sj prop was created by gaz3359
So im running a sj front prop on the rear of my jimny for the sj transfer box.the uj at the diff has play can anyone guide me in the right direction as to what uj i will need as i cant remember if the prop is off a 410 or 413.seen a few uj's advertised saying that they fit both but want to be sure cheers
25 Sep 2015 10:33 #152525
by j999pre
Grey pick up Jimny
Replied by j999pre on topic rear propshaft uj question sj prop
I'm in a similar boat the uj I got from sush has play in it but it's an internal c clip uj not external like the other end so I'm investigating once removed. The other prop I got is a 410 mini prop so can't be used either. Not my finest purchase! This is all I'm waiting on to finish the lobster install
Grey pick up Jimny
25 Sep 2015 10:41 #152526
Replied by mlines on topic rear propshaft uj question sj prop
Sadly you need to identify the exact prop you have as the SJ range varied.
The most common one is identical to the one required for Jimny props and is here.... www.bigjimny.com/store/service-items-and...universal-joint.html
but make sure its what you need first
- gaz3359
25 Sep 2015 12:19 #152530
by gaz3359
Replied by gaz3359 on topic rear propshaft uj question sj prop
Many thanks for the replys is there any way to tell what prop I've got ? If i measured the uj would that work ?
25 Sep 2015 18:37 #152543
by facade
Replied by facade on topic rear propshaft uj question sj prop
A standard jimny UJ is QL219 or ql529 ( with a grease nipple) Blueprint equivalent ADK83901
size is 25mm cup dia x 63.8 mm between the outer edges of the caps (the distance between the circlips on the outside of the joint).
The sj 410 is listed as QL11009 which is 25mm cup dia and 40mm between the internal circlips = inside the yoke on grooves in the caps (very weird.)
There are only the two listed in my old QH catalogue.
25 Sep 2015 19:34 - 25 Sep 2015 19:35 #152551
There are
25mm x 63.8mm (the more popular one and the one in my store)
23.82 x 61.30mm
plus I am sure there was an earlier SJ410 one on the skinny propped on with the early transfer box but I cannot see that one listed.
23.82 x 61.30mm
Last edit: 25 Sep 2015 19:35 by mlines.
Time to create page: 0.101 seconds
