Indicators not working Hazzard light ok.
- daggs5
24 Sep 2015 11:39 #152474
by daggs5
Indicators not working Hazzard light ok. was created by daggs5
Hi,
I have Jimny 2001 indicators just stopped working while in transit.
Hazzard lights still ok.
24 Sep 2015 15:26 #152483
by Halford
Replied by Halford on topic Indicators not working Hazzard light ok.
well I maybe going out on a limb but I''d hazzard a guess that the bulbs are OK :dry:
I'd suspect the stalk is at fault
IMO
IMO
- fozzie
24 Sep 2015 15:45 #152485
by fozzie
Replied by fozzie on topic Indicators not working Hazzard light ok.
Has the indicator relay failed or got loose? I'm sure the hazard and indicator relays are separate beasties!
24 Sep 2015 16:07 #152488
Replied by Daniel30 on topic Indicators not working Hazzard light ok.
Think the hazards are on a different fuse?
24 Sep 2015 17:00 #152490
by facade
Replied by facade on topic Indicators not working Hazzard light ok.
The early ones are, one fuse is TURN/BACK so I guess it does the reverse lights too, the other is HAZARD/HORN.
The later ones have a secret special electronic box for the flasher, and the wiring diagram makes no sense
So do the reverse lamps work?
If the fuse is gone you may find the fault is with the reverse lamps or their wiring.
- daggs5
25 Sep 2015 00:52 #152519
by daggs5
Replied by daggs5 on topic Indicators not working Hazzard light ok.
Thank you for your replies
It was a fuse
Regards
Darryl
It was a fuse
Regards
Darryl
Time to create page: 0.134 seconds
