bigger engine or lower gears
- ddaann88
21 Sep 2015 21:06 #152349
by ddaann88
bigger engine or lower gears was created by ddaann88
Right I'm currently swapping the jimny axles for Nissan patrol ones I know this will cause a few problems with the standard engine, should I swap the engine for a bigger one or put in a lower range transfer box, thanks for any Help the jimny is only used for off road
21 Sep 2015 21:25 #152350
by Busta
Replied by Busta on topic bigger engine or lower gears
Gearing first. Otherwise you'll end up spending more on clutches than the new transfer case will cost.
- TomDK
21 Sep 2015 21:57 #152352
by TomDK
Replied by TomDK on topic bigger engine or lower gears
Agree with Busta.
But why put such massive axles on a tiny Jimny ?
- ddaann88
22 Sep 2015 16:44 #152376
by ddaann88
Replied by ddaann88 on topic bigger engine or lower gears
Ok thanks its mainly for strength and so I can run bigger tyres plus they look cool
- TomDK
23 Sep 2015 08:50 #152409
by TomDK
I adds loads of weight to unsprung weight, which does nothing good to how to car handles.
Also, for the same money you can install uprated shafts and CVS.
Time to create page: 0.088 seconds
