Oil catch can
- gus2000
11 years 2 months ago #152009
by gus2000
Oil catch can was created by gus2000
From
oilcatchcan.com/
“As the EPA and the powers that be mandated stricter emission laws the system was refined more and more ultimately evolving into what we have today. A completely sealed system that uses the vacuum provided by the intake manifold to draw these vapors out, and the filtered fresh makeup air is drawn from the main air intake system and filtered by the main air filter. This results in very clean emissions, but the unintended issues are the detonation or “knock” that occurs when oil is introduced into the combustion chamber that the knock sensors pick up (before we can hear it) and pull timing to protect the engine from damage, and thus reduced power. Another result is the carbon buildup on the valves & piston tops (any techs reading this can surely verify the amount) also resulting in decreased performance and less power made.”
“The purpose of a proper oil separating catch can is to route these gasses through a baffle system that provides the most contact possible with the outer surface resulting in the oil being trapped and removed from the other gasses that do continue on through the intake and are burnt and consumed. It does NOTHING else in ANY way to the engine oil itself….it can’t.”
Homemade oil catch can.
The can
installed on the engine
Testing: after 200 km on the road, and 5 hours in off road
¿What do you think?
Gustavo
The can
¿What do you think?
Gustavo
- Shima
11 years 2 months ago #152013
by Shima
Replied by Shima on topic Oil catch can
That's breathing a lot of oil. I'd be worried as they arent meant to fill up that fast. I had one on my big car and it hardly filled up at all.
- Johnniehec
- Thank you received: 56
11 years 2 months ago #152039
by Johnniehec
Replied by Johnniehec on topic Oil catch can
I had a v8 in a RangeRover that used to blow oil out the breathers. I piped them al into a 1 Lt oil can. I drove it from Aberdeenshire all the way to the offroad show at Trentham Gardens, had to stop a couple of times to empty the oil back into the engine!
- gus2000
11 years 2 months ago #152040
by gus2000
Replied by gus2000 on topic Oil catch can
11 years 2 months ago #152052
by Rhinoman
Replied by Rhinoman on topic Oil catch can
Are you sure that your catch can isn't causing a restriction and increasing crankcase pressure? with a good engine you should get hardly anything in there, the baffle in the cam cover is intended to catch the oil and only a vapour should be present in the PCV system.
The article that you quote massively overstates any issues but then it does seem to have been copied from a site that sells oil catch cans.
The following user(s) said Thank You: Shima
- Thank you received: 706
11 years 2 months ago #152073
Replied by jackonlyjack on topic Oil catch can
The following user(s) said Thank You: gus2000
Time to create page: 0.115 seconds
