Brake & Fuel Lines - Replacement
  • Venter
15 Sep 2015 10:02 #152008 by Venter
Brake & Fuel Lines - Replacement was created by Venter
Hi, I'm shortly going to be replacing my brake and fuel lines and am heading to the motor factors tomorrow morning to buy parts.
Can anyone please give me a list of what's needed, with dimensions too?
15 Sep 2015 17:31 #152022 by facade
Supply pipe 5/16" = 8.0 mm (1 front to rear)
Return & vent 1/4" = 6.3mm (2 front to rear)
Brake pipes are 3/16, if you are changing the fuel pipes, the brake pipes will be shot too. (2 front to rear)
Boxfull of brake unions: threaded right to the end BP9 rings a bell
On mine the supply & return pipes were flexible plastic from the tank to the steel pipes, so I ended up leaving 15mm of steel pipe sticking out to join to, rather than drop the tank and discover that I couldn't connect at the fuel pump.
Fuel injection hose 1/4" ID & 5/16" ID plus clips to match
New plastic clips to hold to chassis, or some really long Zipties and as many of the old ones as you can save.
- See more at:
www.bigjimny.com/index.php/forum?view=to...id=7&id=52735#101935
www.bigjimny.com/index.php/forum?view=to...tid=7&id=48053#57232
www.bigjimny.com/index.php/forum?view=to...tid=7&id=48053#57228
www.bigjimny.com/index.php/forum?view=to...d=54160&limitstart=0
The following user(s) said Thank You: GuardianAngel, Venter
  • Venter
15 Sep 2015 21:33 #152034 by Venter
Replied by Venter on topic Brake & Fuel Lines - Replacement
Thanks facade, good info
  • Venter
16 Sep 2015 15:29 #152063 by Venter
For the fuel lines, can I also use the cheap copper type as for the brake lines, or must I go steel?
16 Sep 2015 17:17 #152069 by facade
Copper is fine, AFAIK it doesn't react with fuel. Fuel pressure is way below brake pressure.
Be careful to secure it though, as copper work hardens and snaps if it gets to wave about under vibration.
21 Sep 2015 17:28 #152336 by Johnniehec
Burst a brake line at the last off road event, a pin hole just as the pipes turn above the rear spring. Cut it, hammered it flat and bent it over to get home with front brakes only.
Both pretty rusty so took them off at the weekend but disturbed a fuel line which are in a similar condition. I've ordered 10m 8mm plastic covered microbore plumbers copper pipe to replace all three. Going to try cutting a "hatch" in the floor above the fuel pump rather that drop the tank as I'm fairly sure all the bolts will be rusted and break. The two inch body lift makes it much easier.
