NewExhaust
  • ronm
11 years 2 months ago #151831 by ronm
NewExhaust was created by ronm
Hi advice needed
Just fitted entire new exhaust to my 2001 Jimny pickup.
Including cat and sensor .
1) Having torqued all connections per manual in true aftermarket form I have a slight blow between the down pipe and link pipe. Does anyone know if jointing paste is advisable on this joint as fitted with stainless crushable gasket.(birds nest type)
2)Back box sits at slight oddball angle with tail pie angled slightly down causing box to bang on cross member near rubbermounts. Any thoughts on twisting this without resulting to oxy on the link pipe
  • Daniel30
11 years 2 months ago #151832 by Daniel30
Replied by Daniel30 on topic NewExhaust
Are all the rubber hangers ok??
  • ronm
11 years 2 months ago #151834 by ronm
Replied by ronm on topic NewExhaust
Hi Daniel
Yes all mountings seem ok but not much give in joint on back box. think bend in link pipe fractionally out
  • Tadpole
11 years 2 months ago #151837 by Tadpole
Replied by Tadpole on topic NewExhaust
ronm wrote: Hi advice needed
Martin had this issue I'm sure not so long back worth having a search, however I think he reversed the 'stainless crushable gasket' refitted & all was well ......... :unsure:
  • ronm
11 years 2 months ago #151838 by ronm
Hi Tadpole will check it out
  • Daniel30
11 years 2 months ago #151841 by Daniel30
Yeah I think he used the old gasket
Time to create page: 0.115 seconds
