Sump oil leak
- Sprocket
12 Sep 2015 07:31 #151782
by Sprocket
Sump oil leak was created by Sprocket
Hi
I've got a slight oil leak from the sump, just the odd drop of oil on the garage floor. It's actually been there for a couple of years and I've been lazy about fixing it. Before I get the spanners out just wonder if anyone had removed the sump and new of any potential pitfalls?
Thanks
Thanks
12 Sep 2015 08:18 - 12 Sep 2015 08:27 #151786
by facade
Replied by facade on topic Sump oil leak
You will really need a new sump. They are made of unobtanium* :ohmy: with a high iron content, so they rust and go porous.
If you are lucky, with the sump off, you will see a couple of marks on the inside, then clean the oil with powerful solvents, derust the outside, and either braze up the holes, or simply coat the outside in leak-fix. (I'd go over the braze with leak-fix anyway)
There is no gasket, just RTV.
AFAIK, you can remove the sump in situ, but the axle might need to drop down a bit.
Suzuki are very good at sealing joints**, so it wont leak there, but on the single cam, there is a known seal failure at the back of the cam, check it isn't this.
*You try getting a second hand one that isn't as rusty as your own.
**the lack of oil everywhere causes terrific rust problems, that you don't see on a LandRover
Last edit: 12 Sep 2015 08:27 by facade.
- gusthegorilla
12 Sep 2015 08:53 #151788
by gusthegorilla
Replied by gusthegorilla on topic Sump oil leak
UNOBTANIUM ??
Like Guinness...pure genius
- Sprocket
12 Sep 2015 09:13 #151789
by Sprocket
Replied by Sprocket on topic Sump oil leak
So not the easy half hour job on a Sunday afternoon I was hoping for then.
- mickt
12 Sep 2015 10:53 #151794
by mickt
Replied by mickt on topic Sump oil leak
If you clean the sump in situ(difficult I know especially the right hand side unless you have small hands(baby size)) and can identify the porous patch then the two pack epoxy putty that sets rock hard is often a good fix. We used to use it on the aircraft as a dent filler to smooth the airflow until a down time could be scheduled for a replacement/repair. We had a B757 with a dent on the leading edge of a horizontal tail stabiliser flying about for years no problems.We use to call it hermetal but there are a number of brands on the market. The one I have now is called Milliput and consists of a yellow and grey length of putty which you mix in equal lengths (just cut the amount of each with a sharp craft knife) and mix together until the colours have combined into an even mix. It is easy to use and can be sanded, painted or whatever once its hardened.
- Sprocket
12 Sep 2015 11:21 #151795
by Sprocket
I'm pretty sure its the gasket that is leaking. Before I start I'll have a careful check round for rust patches.
Time to create page: 0.086 seconds
