lift kit
  • Kev2477
11 years 2 months ago #151685 by Kev2477
lift kit was created by Kev2477
does any body no what is needed for a 1.5" lift kit or 2" lift kit and are they easy to fit yourself ordered my modulars and tyres wanting to spend some more money cheers in advance ryan
  • iloveics
11 years 2 months ago - 11 years 2 months ago #151688 by iloveics
Replied by iloveics on topic lift kit
People will tell you, you"need" a lot of things. What do you NEED for a 2" lift, 2" longer springs or spring spacers.
Ideally you also want longer shocks or shock spacers, longer brake lines ( not req if you leave the anti-roll bar on )
And Ideally you'll want caster correction bushes, but lift it and see how you feel driving it. I don't feel I need any for only 2" of lift.
Fitting new springs or spacers is very easy.
Jack up the chassis use axle stands. Use the jack on the axle, undo the lower shock bolts and lower the axle.
You will find fitting longer brake lines first ( if you want them) will make your life 10x easier getting the springs in and out.
Last edit: 11 years 2 months ago by iloveics.
  • Kev2477
11 years 1 month ago #152832 by Kev2477
Replied by Kev2477 on topic lift kit
my lift kit has come and the springs are differnt sizes are they suppose to be and if so wich way round do they go thanks ryan
11 years 1 month ago #152835 by j999pre
Replied by j999pre on topic lift kit
Long ones on the front
If your Long ones are also slightly different then the longest goes on the drivers front
Grey pick up Jimny
  • Kev2477
11 years 1 month ago #152837 by Kev2477
cheers much appreciated
Time to create page: 0.088 seconds
