Help wanted on recurring fault codes.
  • Zorbathegeek
06 Sep 2015 19:40 - 06 Sep 2015 19:41 #151453 by Zorbathegeek
Help wanted on recurring fault codes. was created by Zorbathegeek
Hi Guys.
As per the title, I'm getting a problem on my wifes 2003 Jimny with recurring fault codes.
P0130. O2 Sensor Circuit. Bank 1. Sensor 1.
P0133. O2 Sensor Circuit. Slow response. Bank 1. Sensor 1.
I've been able to clear the codes using Dash Command but they reappear after a week or so when the engine management light comes back on.
I replaced this sensor a few months ago which seemed to cure the problem for a month or two but now the issue has re-appeared.
Any ideas please ?
[img
IMG_0953 by
Last edit: 06 Sep 2015 19:41 by Zorbathegeek. Reason: Remove Flickr name.
07 Sep 2015 07:25 #151467 by facade
Does the engine use oil? Do you use magic fluids in the oil/petrol? Does it use water?
Burning oil can contaminate the oxygen sensor, although modern car oils have had most of the zinc anti-wear additives taken out, motorbike oils and diesel engine oils haven't. Anti-wear additives in magic fluids could be anything.
The silicates in green or blue antifreeze also poison the sensor.
First thing though, at no cost, is to carefully check the connections and wiring, then check that the alternator is charging properly, as low battery voltage can sometimes cause spurious faults to be flagged.
The following user(s) said Thank You: Zorbathegeek
  • Zorbathegeek
07 Sep 2015 17:36 #151497 by Zorbathegeek
Replied by Zorbathegeek on topic Help wanted on recurring fault codes.
Cheers for the response facade.
Luckily, the engine uses no oil or water and I don't add any "magic" fluid either.
I'll do as you suggest and check the connection again and also the alternator to ensure it's charging properly.
I'm now thinking it could be the fact that the replacement O2 sensor was a "cheapy" from ebay and maybe I should invest in a genuine Suzuki sensor ?
07 Sep 2015 18:19 #151504 by Rhinoman
Check the exhaust manifold for leaks or cracks they will result in false readings from the O2 sensor.
09 Sep 2015 18:42 #151630 by kirkynut
What company's petrol do you normally use?
If it begins with T and is not Total or Texaco and you get it with your shopping, run the tank empty and try a few tanks of proper petrol company fuel.
Solved the same issue on both my Jimny and the Mrs BMW!
  • Zorbathegeek
09 Sep 2015 19:33 #151635 by Zorbathegeek
Never ocurred to me that might be the problem.
Cheers for the heads up, I'll tell the wife to stop using T****s petrol for a while and see if that cures it.
Time to create page: 0.117 seconds
