Front shock top mount ripped out
  • thompo
31 Aug 2015 22:22 #151101 by thompo
Front shock top mount ripped out was created by thompo
Project rust bucket strikes again lol.
Hit a hole in a grass verge avoiding a tractor on a narrow lane.
And shortly after heard some knocking from the front end.
Anyone got any pictures of how the mount should look or the dia of the hole for the shock so I can rebuild it?
I would strip the other side but I will probably have to cut the top of the shocks to get them out as they too are rusty lol. (hence why I'm looking a lift kit asap).
Hopefully I can cut the nut off this shocks and re-use until I can source a lift.
  • fozzie
01 Sep 2015 09:16 #151106 by fozzie
Replied by fozzie on topic Front shock top mount ripped out
Hopefully, if you can cut the nut off the top of the shock you can remove the missing metal and see what the original hole was.
  • Daniel30
01 Sep 2015 10:07 #151107 by Daniel30
Replied by Daniel30 on topic Front shock top mount ripped out
thompo wrote: Project rust bucket strikes again lol.
This is my drivers side front mount hope it helps
[IMG
  • Jimny-Dave
01 Sep 2015 11:46 - 01 Sep 2015 11:51 #151109 by Jimny-Dave
Replied by Jimny-Dave on topic Front shock top mount ripped out
Shock pin mount is 10mm (metric fine as standard), so a 10.5mm / 11mm hole...
To get it going for now, you could put a nice big repair washer under and over the missing metal and clamp them together using the shock's pin mount...
Your local fastenings supplier should be able to assist...
Last edit: 01 Sep 2015 11:51 by Jimny-Dave.
