Clutches!
- Basketcase
Any help would be great! Cheers guys
- mickt
- Nicks_Jim
www.bigjimny.com/index.php/forum?view=to...217&start=540#142918Basketcase wrote: Clutch on the Jimmy is on its way out....again!!! Does anyone have any experience of the heavy duty 4paddle clutches you can get? I'm sick of changing it every year now or are there any other clutch kits you ca get for the Jim other than the exceedy one? I.E does the 1.6 vita ta clutch for and would that be any better for off-roading than the normal Jimny one?
Here's my suzuki Kap 4 paddle clutch which i would recommend
- Basketcase
mickt wrote: How many miles do you cover to eat clutches? If not a lot then something is amis,s for example is the flywheel surface nice and flat and unmarked or do you perhaps drive with your foot resting on the clutch pedal. A lot of people do and don't realise they do. Is the cable adjusted correctly? I am 67 and over time I have owned and driven many different cars and vans and never had to replace a clutch through my ownership. There was one I had to do on a van that I bought off ebay and on the way home found it slipped in high gear if pulling away in too high a gear. But as I had technically not owned that for any length of time I don't count that as worn out by me.
I don't do many miles but it's 95% off road miles this last clutch has lasted 2 years of off-roading once a month and the occasional trip out to work or shops but probably only done 10k miles of that. I think it's the off road use that's killing the clutch
- mickt
