Clutches!
  • Basketcase
11 years 2 months ago #151017 by Basketcase
Clutches! was created by Basketcase
Clutch on the Jimmy is on its way out....again!!! Does anyone have any experience of the heavy duty 4paddle clutches you can get? I'm sick of changing it every year now or are there any other clutch kits you ca get for the Jim other than the exceedy one? I.E does the 1.6 vita ta clutch for and would that be any better for off-roading than the normal Jimny one?
Any help would be great! Cheers guys
  • mickt
11 years 2 months ago #151018 by mickt
Replied by mickt on topic Clutches!
How many miles do you cover to eat clutches? If not a lot then something is amis,s for example is the flywheel surface nice and flat and unmarked or do you perhaps drive with your foot resting on the clutch pedal. A lot of people do and don't realise they do. Is the cable adjusted correctly? I am 67 and over time I have owned and driven many different cars and vans and never had to replace a clutch through my ownership. There was one I had to do on a van that I bought off ebay and on the way home found it slipped in high gear if pulling away in too high a gear. But as I had technically not owned that for any length of time I don't count that as worn out by me.
  • Nicks_Jim
11 years 2 months ago #151026 by Nicks_Jim
Replied by Nicks_Jim on topic Clutches!
Basketcase wrote: Clutch on the Jimmy is on its way out....again!!! Does anyone have any experience of the heavy duty 4paddle clutches you can get? I'm sick of changing it every year now or are there any other clutch kits you ca get for the Jim other than the exceedy one? I.E does the 1.6 vita ta clutch for and would that be any better for off-roading than the normal Jimny one?
www.bigjimny.com/index.php/forum?view=to...217&start=540#142918
Here's my suzuki Kap 4 paddle clutch which i would recommend
  • Basketcase
11 years 2 months ago #151037 by Basketcase
Replied by Basketcase on topic Clutches!
mickt wrote: How many miles do you cover to eat clutches? If not a lot then something is amis,s for example is the flywheel surface nice and flat and unmarked or do you perhaps drive with your foot resting on the clutch pedal. A lot of people do and don't realise they do. Is the cable adjusted correctly? I am 67 and over time I have owned and driven many different cars and vans and never had to replace a clutch through my ownership. There was one I had to do on a van that I bought off ebay and on the way home found it slipped in high gear if pulling away in too high a gear. But as I had technically not owned that for any length of time I don't count that as worn out by me.
I don't do many miles but it's 95% off road miles this last clutch has lasted 2 years of off-roading once a month and the occasional trip out to work or shops but probably only done 10k miles of that. I think it's the off road use that's killing the clutch
  • mickt
11 years 2 months ago #151064 by mickt
I should think that most of the time offroad is spent in the low gears and so the speed of the drive input shaft is low and hence the chance of clutch slip is low. I assume you replace all of the clutch components when you do the clutch and not just the friction plate. I also assume that the brake/s are not dragging which can cause more loading of the drivetrain.
11 years 2 months ago #151067 by mlines
Replied by mlines on topic Clutches!
I suspect that the use of 235/75-R15 tyres without a change in transfer box ratio is putting a strain on the standard clutch. Sub-consciously you are probably slipping it more.
Time to create page: 0.089 seconds
