noob question about throttle body
- saboor73
28 Aug 2015 19:47 #150869
by saboor73
noob question about throttle body was created by saboor73
I have heard that throttle body have a screw to lean out air is something like this present in m13a tb it would be very nice to slightly lean out air to make fuel mixture rich while driving on high altitudes
- saboor73
28 Aug 2015 20:31 #150875
by saboor73
Replied by saboor73 on topic noob question about throttle body
where that screw is located on? M13a tb?
- troggy
24 Nov 2015 20:57 #157140
by troggy
Replied by troggy on topic noob question about throttle body
try using milk a a 'coolant'! :ohmy:
24 Nov 2015 22:04 #157146
by kirkynut
You'll need to explain this! What do you mean?
Replied by kirkynut on topic noob question about throttle body
troggy wrote: try using milk a a 'coolant'! :ohmy:
24 Nov 2015 23:05 #157153
by Busta
Replied by Busta on topic noob question about throttle body
The ECU monitors the air/fuel ratio using the 1st Lambda sensor in the exhaust and adjusts the mixture accordingly, so it will automatically compensate for less oxygen at higher altitudes. There are no settings on the throttle body that will alter the fuel ratio.
27 Nov 2015 20:08 #157337
by Rhinoman
Replied by Rhinoman on topic noob question about throttle body
Compensation for altitude is performed using the barometric pressure values derived from the MAP sensor.
Time to create page: 0.111 seconds
