Transfer box bracket
11 years 2 months ago - 11 years 2 months ago #150989
by kirkynut
Replied by kirkynut on topic Transfer box bracket
Ah, right!
Yeah, get heavy duty ones from Jimny Bits or one of the others. The standard ones are rubbish. Just do one at a time with the box in situ!
Last edit: 11 years 2 months ago by kirkynut.
The following user(s) said Thank You: Daniel30
11 years 2 months ago #150990
Replied by Daniel30 on topic Transfer box bracket
Great stuff Cheers chaps
11 years 1 month ago - 11 years 1 month ago #152972
by Paul4A
1999 T registered Jimny. Early G13BB SOHC engine.
Replied by Paul4A on topic Transfer box bracket
Forgive my basic question here but I'm new to Jimny's. My partner's old Jimny gives a little vibration when pulling away and I'm doing a little research on possibilities.
Would someone please clarify what the difference is between the aluminium rear engine mount, apparently often incorrectly called the main gearbox mount, and the aluminium case transfer bracket. They look very different in photographs but I'm getting confused as to where they go and how they are mounted (solid or rubber bushed) due to lack of experience and the terminology used.
Links I've looked at include:
for the engine mount
www.bigjimny.com/store/rear-engine-mount-gearbox-mount.html
for the transfer case bracket
www.offroad-armory.com/store/index.php?r...54_20&product_id=211
And where do the transfer box bushes go?
www.jimnybits.co.uk/shop/jimny/drivetrai...ushes/prod_1088.html
Thanks
Thanks
Last edit: 11 years 1 month ago by Paul4A.
11 years 1 month ago #152975
by j999pre
Grey pick up Jimny
Replied by j999pre on topic Transfer box bracket
Gearbox mount is 2 pieces of steel with rubber between, all bonded together and is located under the gear linkage remote on the tubular cross member
The transfer box has a driver's side bracket long with 2 mounts and a nearside short with one mount. The mounts bolt to the chassis and the transfer box 14mm nut chassis side 12mm bolts into transfer box
The rubber mounts isolate the transfer box from the chassis in the places add mentioned above
So if you buy new transfer box mounts either reuse your old bushes, but new oem ones or Uprated ones
Grey pick up Jimny
The following user(s) said Thank You: Paul4A
11 years 1 month ago #152991
by Paul4A
Thanks for that clarification.
I had a quick crawl underneath this afternoon and can readily see the transfer bracket. I can feel the rubber bushes for it on the drivers side of the car so would have assumed there were two of them but the link suggests three.
The rear engine mount is much more difficult to see with the car on the ground.
I did find a some helpful photographs from elsewhere online.
11 years 1 month ago #152994
by Busta
Replied by Busta on topic Transfer box bracket
Rear engine mount is bottom left of the second picture you posted.
Time to create page: 0.103 seconds
