Rear Door
  • Zee Zee Top
11 years 2 months ago #150571 by Zee Zee Top
Rear Door was created by Zee Zee Top
Please excuse a question from a non-technical girl but someone has very kindly put a small dent in my rear door which I want to get fixed by one on the dent removal comanys.
Before they arrive I want to remove the rear trim panel to save time and reduce the risk of more damage.
Does this simply pull off? or is it a bit more complicated.
many thanks, Jean
  • NineCherries
11 years 2 months ago #150574 by NineCherries
Replied by NineCherries on topic Rear Door
On my 08 plate it was just pull off. Start at the bottom of the panel and work along the bottom edge, teasing it when you are close to a retaining clip. Work up both sides towards the windscreen (I think there are a couple of trim clips towards the moddle of the panel too) then take it easy along the top as mine kinda slipped under the screen rubber. It takes less than 5 mins to take off.
How soon are you doing it? I plan to take mine off again soon to add some sound deadening, I could take a couple of pics when it's off to show you clip location.
  • Zee Zee Top
11 years 2 months ago #150577 by Zee Zee Top
Replied by Zee Zee Top on topic Rear Door
NineCherries wrote: On my 08 plate it was just pull off. Start at the bottom of the panel and work along the bottom edge, teasing it when you are close to a retaining clip. Work up both sides towards the windscreen (I think there are a couple of trim clips towards the moddle of the panel too) then take it easy along the top as mine kinda slipped under the screen rubber. It takes less than 5 mins to take off.
Thanks, pics would be great, going to have a go over the bank holiday or the next weekend.
  • Tadpole
11 years 2 months ago - 11 years 2 months ago #150580 by Tadpole
Replied by Tadpole on topic Rear Door
Stored away in my 'How 2' favourites hth ... ;)
edit sorry it was the wrong door ... :whistle:
Have a search for rear wiper replacement, I think Halford/Hellijohn did it, this has pics showing pop clip positions etc.
Found it post #71590 www.bigjimny.com/index.php/forum?view=to...=8&id=17232&start=96
Last edit: 11 years 2 months ago by Tadpole.
  • Zee Zee Top
11 years 2 months ago #150592 by Zee Zee Top
Tadpole wrote: Stored away in my 'How 2' favourites hth ... ;)
Brill...thanks Tadpole
  • Tadpole
11 years 2 months ago #150612 by Tadpole
Your very welcome, I also recently bought a set of 'tools' this set have been very useful ... ;)
Time to create page: 0.099 seconds
