Identfiy the Part Please
23 Aug 2015 14:55 #150417 by bryn
Have a look at the photos if you would please and identify the part and secondly is its replacement is it just a unscrew and replace or something more.
I hope you can see the photos from the link. It is a blue topped nut with 2 wires coming from it one of which has come away. I'm guessing its a solenoid or sensor of some description on the underside of the car screwed into the 4x4 drive.
I had the car in 4xdrive, put it up on a ramp pulled the wire which was hanging by a thread and one of the wires came away. I then drove off the ramp, the 4xdriive indicator was flashing, put it in normal drive and now it won't go into 4xdrive as per the indicator.
Much appreciated
bryn
s1378.photobucket.com/user/brynandlorna/...zpscxc72tf6.jpg.html
s1378.photobucket.com/user/brynandlorna/...zpswjjt0ldv.jpg.html
23 Aug 2015 17:27 #150438 by bryn
Replied by bryn on topic Identfiy the Part Please
Researching the web and I'm thinking it could be the 4 wheel drive selector solenoid but could do with it confirming please.
When you click on the links they take about 5 secs to down load so bare with it
thanks
bryn
23 Aug 2015 20:00 #150460 by Busta
Replied by Busta on topic Identfiy the Part Please
Click on the box to the right of the picture that says IMG and paste it in your message to include a picture:
[IMG
25 Aug 2015 11:43 #150588 by bryn
I managed to id the part which is a 4x4 switch attached to the front of the Transfer case.
BE AWARE WHEN REPLACING THERE IS A BALLBARING WHICH IS INSIDE THE SWITCH SOCKET WITHOUT WHICH IT WILL NOT OPERATE.
I lost it not knowing it was there. (Found it by luck)
  • Daniel30
25 Aug 2015 12:14 #150591 by Daniel30
Replied by Daniel30 on topic Identfiy the Part Please
Thanks for sharing the information and the heads up on the bearing, how lucky was that to find it :woohoo: glad you got it sorted
Time to create page: 0.098 seconds
