Stainless exhaust system
23 Aug 2015 04:23 - 23 Aug 2015 04:25 #150393 by skywalker65
Hi All,
Giving some consideration to getting a system for my VVT.
Any do's and don'ts
Thinking about leaving the stock exhaust manifold then going stainless from that.
Doing away with the cat and going straight through.
Will keep stock system for its yearly appointment
Any recommendations on bore diameter etc and possible recommended companies to do the work please
If in doubt ...... Flat out ??
Last edit: 23 Aug 2015 04:25 by skywalker65. Reason: left part of message off
  • Daniel30
23 Aug 2015 07:46 #150398 by Daniel30
Replied by Daniel30 on topic Stainless exhaust system
If you look further down on this page to new cat topic there is a cat to replace the original that is a lot smaller so you wouldn't have to keep changing it about, ZookFastback has a 2" system ask him how his sounds etc :) as for who sells/makes them I would think you could Google firms near to you :)
  • Daniel30
23 Aug 2015 07:47 #150399 by Daniel30
Forgot to add let me know how you get on would like a new system for mine ;)
  • ZookFastback
23 Aug 2015 09:09 #150402 by ZookFastback
Replied by ZookFastback on topic Stainless exhaust system
Here is the sound with Extractors, 100 CPSI Cat, 2" system and straight-through rear exhaust (rear exhaust has the sound deadening stuff in it but no bends n turn.
CLICK HERE
23 Aug 2015 10:37 #150405 by Halford
Replied by Halford on topic Stainless exhaust system
Look for local powerflow supplier/fitter
Mine is 50mm, makes sense getting at least rear pipe section with back box, as I discovered a problem trying to fit replacement rear pipe to s/s back box as replacement pipes are different dia to OEM pipes.
Also get tow bar fitted first as a fabricated back box will almost certainly be in the way if you come to fit one at a later date.
Vid clip of my box in halfords dog taxi thread in myjimny
  • Daniel30
23 Aug 2015 11:15 #150406 by Daniel30
Halford have you got a full stainless system? have you kept the cat?
Time to create page: 0.111 seconds
