Problem fitting steering damper
  • Filfrasen
11 years 2 months ago - 11 years 2 months ago #150334 by Filfrasen
Problem fitting steering damper was created by Filfrasen
I have one off this kit (Armstrong)
www.jimnybits.co.uk/shop/jimny/suspensio...mper-kit/prod_8.html
The bracket to the frame dont sems to fit so well.
The frame bracket and damper come very close to the steering arm (adjusteble arm from steering box to weel),
and it vill probably be problems when the spring kompress max.
The manual shows a pic on a different frame bracket,but i am shore i have mont it correct.
My Jimny is a -2005 vvt,steering weel on left side, not lifted.
In this kit only for lifted Jimnys ?
Regards
Nicklas from Sweden
Last edit: 11 years 2 months ago by Filfrasen.
  • reaper
11 years 2 months ago #150335 by reaper
Replied by reaper on topic Problem fitting steering damper
You may have to fit it on the other side as you have a LHD
  • Filfrasen
11 years 2 months ago - 11 years 2 months ago #150338 by Filfrasen
Replied by Filfrasen on topic Problem fitting steering damper
I move the bracket more to the front off my car (fornt side of the rond pipe between frames),
it works ok.
The damper cant now not hit something now.
I take a testdrive, its like a diffrent car to drive. :woohoo:
I strongly rekomend a steeringdamper on this cars. :)
  • Filfrasen
11 years 2 months ago - 11 years 2 months ago #150339 by Filfrasen
reaper wrote: You may have to fit it on the other side as you have a LHD
I have to mont the smaler ones off the brackets to the steering box side, no adder choise.
Last edit: 11 years 2 months ago by Filfrasen. Reason: .
Time to create page: 0.082 seconds
