Rear silencer
  • Daniel30
08 Aug 2015 12:32 #149394 by Daniel30
Rear silencer was created by Daniel30
As I'm in rust prevention mode I have been under the back of the jimny, The rear silencer is rotten and the heat shield rattles so had a look at the first join and the nuts are rotten, the next join with the spring things on I can't move the nuts so do I cut the back box off and get something to rejoin the new back box on?
Cheers
  • Daniel30
08 Aug 2015 12:35 #149395 by Daniel30
  • Daniel30
08 Aug 2015 12:36 #149396 by Daniel30
08 Aug 2015 12:39 #149397 by Halford
Replied by Halford on topic Rear silencer
could make sense to get the rear pipe section at the same time :unsure:
less than £30 from local autoparts supplier
  • Daniel30
08 Aug 2015 13:00 #149402 by Daniel30
Replied by Daniel30 on topic Rear silencer
Halford wrote: could make sense to get the rear pipe section at the same time :unsure:
Yeah think I would but I don't know how to attach it everything is seized so I was wondering if I cut the exhaust just after the springy thing could I attach the new bit that would attach to the new backbox
08 Aug 2015 13:08 #149408 by Halford
keep trying to loosen the bolts - penetrant and hammers (or get garage to apply heat) or just grind the bolts/nuts off and get new ones
Time to create page: 0.142 seconds
