Oil
- Filfrasen
11 years 3 months ago - 11 years 3 months ago #149344
by Filfrasen
Oil was created by Filfrasen
I have a -2005 VVT Jimny.
What kind of oil is rekomended in my engine ?
Mineral,semi syntetic or syntetic ?
5w-30,10w-40,15W-50 ?
I live i Sweden,wery cold winters somtimes.
Last edit: 11 years 3 months ago by Filfrasen.
- Decklandpt
11 years 3 months ago #149366
by Decklandpt
Replied by Decklandpt on topic Oil
mineral, syntetic or semi syntetic only make a difference if you drive the car very hard or not. has more to do with how long it lasts than anything else i think.
as for viscocity (butchered that one), since you are from a country with cold winters i would go with 5w.
not sure about the 30 tough...i think i use 5w40..
for cold weather low vicocity is recomended because it will lub it up well even befor the oil is up to temperature.
- Grego
11 years 3 months ago - 11 years 3 months ago #149371
by Grego
Replied by Grego on topic Oil
I asked this a while ago and the opinion was that 5w30 fully synth was the one to go for (handy as I had loads of the stuff for my daily
Last edit: 11 years 3 months ago by Grego.
11 years 3 months ago #149380
by kirkynut
Have a look at your handbook for the temperature you're in.
- Filfrasen
11 years 3 months ago #149416
by Filfrasen
Replied by Filfrasen on topic Oil
I have buy Champion syntetic 5w-40 today.
Thanks for input
//Nicklas
Thanks for input
//Nicklas
- Decklandpt
11 years 3 months ago #149485
by Decklandpt
i use shell helix ultra 5w40. was the same on the 1.5ddis (not the same oil, but the same "range")
we have some cold-ish winters, about 0ºC at times, and hot summers, 35/37ºc is normal, at times 43/45ºc, and i never had any problems with it. change every 8-ish thousand, and i regularly use all of the engine's rpm. started using it because of the cold starts in the winter, but i think a 10w40 would have the same performance more or less
Time to create page: 0.086 seconds
