Death wobble
- Thank you received: 2004
11 years 3 months ago #149152
Death wobble was created by Lambert
Ain't that always the case, last thing on the list to change and it solves the problem.
11 years 3 months ago #149153
Replied by Daniel30 on topic Death wobble
Least it's sorted and everything is like new
( but yes very annoying)
- Grego
11 years 3 months ago #149162
by Grego
Replied by Grego on topic Death wobble
Dont you just love "local garages"?
I had a similar problem on an old car I had.
Took it in as the bearing was droning, 2 months later the bearing had gone again, so stripped down myself
The hub nut was finger tight and staked but was supposed to be torqued to 150 ft/lbs.
Not only did it wreck the bearing but also the hub and the drive flange.
Garage owner denied all responsibility saying it must have been something I had done(!)....I suppose I did drive it :laugh:
Never found a garage I could trust 100% since
11 years 3 months ago #149169
by Jezz
It's been fettled just a tad.
Replied by Jezz on topic Death wobble
Grego, As the bearing failed the hub nut would probably become loose, Due to the slack in the failing bearing.
More likely that the cheapest bearing with the biggest mark up was used.
- Grego
11 years 3 months ago - 11 years 3 months ago #149198
by Grego
True of a taper roller or similar, but this was a one piece double roller bearing as fitted to MG Maestros (had 5 of them in the 80s/90s), the bearing could disintegrate but the nut was tightened against a 1 piece inner race iirc so would still remain torqued up even if the wheel was loose in the hub.
Became a dab hand at replacing them as it was a common fault, the hardest part was always undoing that f*****g hub nut if it hadnt been undone from the factory, often resorting to using a 3 ft long 1/2 drive on the nut, jacking the car up on the handle of the bar and bouncing up and down on the car
....they were tight :pinch:
Jezz wrote: Grego, As the bearing failed the hub nut would probably become loose, Due to the slack in the failing bearing.
Last edit: 11 years 3 months ago by Grego.
11 years 3 months ago #149203
by Jezz
Are right, That makes sense. I think anyone who has worked on cars has had to resort to the scaff tube or similar at some stage.
Time to create page: 0.089 seconds
