Front Hubs
  • oxford_bloke
09 Nov 2010 13:04 #5824 by oxford_bloke
Front Hubs was created by oxford_bloke
Hi guys,
I'm doing away with the vacuum operated hubs so could you help with other options, as im trying to build a challenge truck
  • ooky_123
09 Nov 2010 15:03 #5825 by ooky_123
Replied by ooky_123 on topic Re: Front Hubs
General consensus is unless you planning on swapping the axles, ASIN Hubs and adapter plates are the way forward. ok, they are freewheeling and you have to physically lock / unlock them, but highly regarded in the SJ world
going rate for a pair (with the cone washers) is about £40 and then you need martin's adapter plates and longer bolts.
  • oxford_bloke
09 Nov 2010 15:09 #5826 by oxford_bloke
Replied by oxford_bloke on topic Re: Front Hubs
so why would you rate ASIN over the AVM hubs on jimnybits?
Cheers for you help so far
Tom
  • ooky_123
09 Nov 2010 15:17 #5827 by ooky_123
the AVM hubs look very nice. To be honest Ive not heard anything good or bad about them. ASIN are more readily available, and given their relative cheapness, I suppose it depends on the depth of your pockets and if the AVM's are really any good or not.
  • oxford_bloke
09 Nov 2010 15:20 #5828 by oxford_bloke
am i right im thinking the asisn are off of an sj. if so could you point me in the direction of some online.
many thanks
Tom
  • ooky_123
09 Nov 2010 15:30 #5829 by ooky_123
check out the difflock classifieds... www.difflock.com
there are a few people breaking SJ's and Vitara's with manual hubs..
not sure if they are ASIN, but here is a set offf a vitara ..
forum.difflock.com/ads_item.php?id=11511
These guys are breaking a SJ's
forum.difflock.com/ads_item.php?id=11410
forum.difflock.com/ads_item.php?id=11371
Might be worth an email to them
